SpotlightManaging loads
Tool
Tool set
Manage Loads
Rigging/Braceworks
The Manage Loads tool allows you to attach, reposition, and remove loads from rigging objects and hanging positions in the model and in schematic views. In the model, the tool can also be activated by selecting Manage Loads from a rigging object/hanging position’s context menu.
Managing loads with the tool is not affected by the auto-positioning options on the Spotlight preferences: Loads and Rigging pane; whether auto-positioning is enabled or disabled, the Manage Loads tool can still be used to attach and reposition loads.
If the option to Orient loads with rigging objects when snapping in 3D is enabled on the Loads and Rigging pane, lighting devices and other load objects that support 3D rotation automatically assume the orientation of the rigging/hanging object when they are attached or repositioned in 3D views. This option does not apply in Top/Plan view, where the Manage Loads tool attaches and repositions loads at a fixed orientation.
When a single load is attached or repositioned, valid rigging/hanging objects are highlighted for precise placement. When multiple loads are attached or repositioned, valid rigging/hanging objects are highlighted, and the loads are moved to the closest point in 3D on the highlighted object.
When repositioning a load on a truss line, the tool’s Reposition mode enables sophisticated truss snapping. This allows you to precisely set the load’s hanging point on the top, bottom, or side of the truss. Using the tool for repositioning is more precise than Attaching existing loads by dragging.
Mode
Description
Attach
Attaches selected load objects to the selected rigging/hanging object, creating an association
Remove
Removes selected load objects from their associated rigging/hanging object, breaking the association
Reposition
Displays control points on all of the load objects attached to a selecting rigging/hanging object, for repositioning the loads.
To display control points on schematic loads, select the schematic load or its associated schematic rigging object.
There are several ways to attach lighting devices and other loads to a rigging object. Loads can be automatically attached when they are inserted and when they are moved in the drawing. For details, see Concept: Attaching loads to rigging objects. In addition, various commands allow you to attach, reposition, and remove loads from rigging objects in the model and in schematic views.
Action
Method
Description
Attaching loads
Insert a load on a rigging object
Symbol insertion
Attaching new loads and Adding lighting devices
Move a load to a rigging object
Click-drag operation
Attach one or more loads to a rigging/hanging object
Manage Loads tool
Load object context menu command
Attaching existing loads with the Manage Loads tool
Repositioning attached loads
Move a load's hanging point in the model and schematic view
Manage Loads tool (model only)
Hanging point control point
Repositioning loads with the Manage Loads tool
Moving schematic loads by control points
Move a load's offset position in the schematic view
Object position control point (schematic only)
Move an offset load onto the schematic rigging object
Drop-down context menu command (schematic only)
Moving an offset load onto the schematic rigging object
Move all offset loads onto the schematic rigging object
Rigging object context menu command (schematic only)
Moving all offset loads onto the schematic rigging object
Removing loads
Remove a load from the rigging/hanging object
Manage Loads tool
Removing loads with the Manage Loads tool
Remove a load from the schematic view
Removing loads in the schematic view
Concept: Rigging objects
Concept: Schematic views
Repositioning loads
Removing loads
